ArcGIS.Desktop.Mapping Namespace / Map Class / GetElevationProfileFromSurface Method / GetElevationProfileFromSurface(IEnumerable<Polyline>,ElevationSurfaceLayer,SurfaceZsMissingHandler) Method
A set of polylines.
Identifies the surface to be used. If null is specified, then the default Ground Surface will be used.
provides options to handle missing Zs in the surface
    Gets an elevation profile for the specified polylines. The Z values of the calculated polyline are populated from the specified Elevation Surface Layer. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    polylines
    A set of polylines.
    surfaceLayer
    missingHandler
    Return Value
    An ElevationProfileResult. If successful, this contains the generated polyline.
    Exceptions
    ExceptionDescription
    polylines cannot be null.
    This Map does not have the specified surfaceLayer.
    This Map does not have a visible Ground Surface Layer.
    Remarks
    The missingHandler will be used to determine what to do if the surface has no data at a particular input geometry point. The corresponding output geometries point or vertex Zs will be set to the value specified in the provided missingHandler.OutputZ property. The missingHandler.OnlyProcessMissingZs parameter can be used to overwrite all Z values or only those that are designated as missing based on a comparison with the InputZ value.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
