ArcGIS.Desktop.Mapping Namespace / Map Class / GetElevationProfileFromSurface Method / GetElevationProfileFromSurface(IEnumerable<MapPoint>,ElevationSurfaceLayer) Method
A set of points.
Identifies the surface to be used. If null is specified, then the default Ground Surface will be used.
Example
    Gets an elevation profile for the specified points. The Z values of the calculated polyline are populated from the specified Elevation Surface Layer. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function GetElevationProfileFromSurface( _
       ByVal points As IEnumerable(Of MapPoint), _
       ByVal surfaceLayer As ElevationSurfaceLayer _
    ) As ElevationProfileResult
    Parameters
    points
    A set of points.
    surfaceLayer
    Return Value
    An ElevationProfileResult. If successful, this contains the generated polyline.
    Exceptions
    ExceptionDescription
    polylines cannot be null.
    This Map does not have the specified surfaceLayer.
    This Map does not have a visible Ground Surface Layer.
    Remarks
    If the surface has no data at a particular input geometry point, then the corresponding output geometry point Z will be set to the value specified in SurfaceZsMissingHandler.DefaultOutputZ.
    Example
    Get Elevation profile from a specific surface
        // find a specific elevation surface layer
        var eleLayer = MapView.Active.Map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "TIN");
        Polyline polyline = PolylineBuilderEx.CreatePolyline();
        MapPoint mapPoint = MapPointBuilderEx.CreateMapPoint(34, -118, SpatialReferences.WGS84);
        List<MapPoint> mapPoints = new List<MapPoint> { mapPoint };
        // get the elevation profile for a polyline / set of polylines
        // use the specific elevation surface layer
        var zResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync([polyline], eleLayer);
        if (zResult.Status == SurfaceZsResultStatus.Ok)
            var polylineZ = zResult.Polyline;
            // process the polylineZ
        // get the elevation profile for a set of points
        zResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(mapPoints, eleLayer);
    Requirements
    ArcGIS Pro version: 3.4 or higher.
