ArcGIS.Desktop.Mapping Namespace / Map Class / GetElevationProfileFromSurfaceAsync Method
    Overload List
    OverloadDescription
    Gets an elevation profile for the specified polylines. The Z values of the calculated polyline are populated from the Ground Surface Layer.
    Gets an elevation profile for the specified polylines. The Z values of the calculated polyline are populated from the specified Elevation Surface Layer.
    Gets an elevation profile for the specified points. The Z values of the calculated polyline are populated from the Ground Surface Layer.
    Gets an elevation profile for the specified points. The Z values of the calculated polyline are populated from the specified Elevation Surface Layer.
    Gets an elevation profile calculated between startPoint and endPoint. Intermediate points are calculated at equal distances between the end points according to the numPoints specified. The Z values of the calculated polyline are populated from the Ground Surface Layer.
    Gets an elevation profile calculated between startPoint and endPoint. Intermediate points are calculated at equal distances between the end points according to the numPoints specified. The Z values of the calculated polyline are populated from the specified Elevation Surface Layer.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
