ArcGIS.Desktop.Mapping Namespace / Map Class / GetElevationProfileFromSurfaceAsync Method / GetElevationProfileFromSurfaceAsync(IEnumerable<MapPoint>) Method
A set of points.
Example
    Gets an elevation profile for the specified points. The Z values of the calculated polyline are populated from the Ground Surface Layer.
    Syntax
    Public Overloads Function GetElevationProfileFromSurfaceAsync( _
       ByVal points As IEnumerable(Of MapPoint) _
    ) As Task(Of ElevationProfileResult)
    public Task<ElevationProfileResult> GetElevationProfileFromSurfaceAsync(
       IEnumerable<MapPoint> points
    Parameters
    points
    A set of points.
    Return Value
    An ElevationProfileResult. If successful, this contains the generated polyline.
    Exceptions
    ExceptionDescription
    points cannot be null.
    This Map does not have a visible Ground Surface Layer.
    Remarks
    If the surface has no data at a particular input geometry point, then the corresponding output geometry point Z will be set to the value specified in SurfaceZsMissingHandler.DefaultOutputZ.
    Example
    Get Elevation profile from the default ground surface
        // get the elevation profile for a polyline / set of polylines
        Polyline polyline = PolylineBuilderEx.CreatePolyline();
        MapPoint mapPoint = MapPointBuilderEx.CreateMapPoint(34, -118, SpatialReferences.WGS84);
        List<MapPoint> mapPoints = new List<MapPoint> { mapPoint };
        var result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync([polyline]);
        if (result.Status == SurfaceZsResultStatus.Ok)
            var polylineZ = result.Polyline;
            // process the polylineZ
            // get the elevation profile for a set of points
            result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(mapPoints);
    Requirements
    ArcGIS Pro version: 3.4 or higher.
