ArcGIS.Desktop.Core.UnitFormats Namespace / IDisplayUnitFormats Interface / SetProjectUnitFormats Method
Example
    SetProjectUnitFormats Method (IDisplayUnitFormats)
    Sets the list of project unit formats for the current project for the given UnitFormatType.
    Syntax
    Parameters
    availableUnits
    defaultUnit
    Example
    Set a Specific List of Unit Formats for the Current Project
      // Note: Must be on the QueuedTask.Run()
      //UnitFormatType.Angular, UnitFormatType.Area, UnitFormatType.Distance,
      //UnitFormatType.Direction, UnitFormatType.Location
      //Get the full list of all available location units
      var all_units = DisplayUnitFormats.Instance.GetPredefinedProjectUnitFormats(
                                                          UnitFormatType.Location);
      //keep units with an even factory code
      var list_units = all_units.Where(du => du.UnitCode % 2 == 0).ToList();
      //set them as the new location unit collection. A new default is not being specified...
      DisplayUnitFormats.Instance.SetProjectUnitFormats(list_units);
      //set them as the new location unit collection along with a new default
                                              list_units, list_units.First());
      //Note: UnitFormatType.Page, UnitFormatType.Symbol2D, UnitFormatType.Symbol3D
      //cannot be set.
    Update Unit Formats for the Project
      var angle_units = DisplayUnitFormats.Instance.GetProjectUnitFormats(UnitFormatType.Angular);
      //Edit the display name of each unit - append the abbreviation
      foreach (var unit in angle_units)
        unit.DisplayName = $"{unit.DisplayName} ({unit.Abbreviation})";
      //apply the changes to the units and set the default to be the first entry
      DisplayUnitFormats.Instance.SetProjectUnitFormats(angle_units, angle_units.First());
      //The project must be saved to persist the changes...
    Requirements
