ArcGIS.Desktop.Core.UnitFormats Namespace / DisplayUnitFormats Class / GetDefaultProjectUnitFormat Method
The default unit format to return
    GetDefaultProjectUnitFormat Method (DisplayUnitFormats)
    Gets the default unit format in the current project for the given UnitFormatType. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetDefaultProjectUnitFormat( _
       ByVal defaultFormatType As UnitFormatType _
    ) As DisplayUnitFormat
    public DisplayUnitFormat GetDefaultProjectUnitFormat(
       UnitFormatType defaultFormatType
    Parameters
    defaultFormatType
    Return Value
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    The default unit formats can vary between projects. If there is no project open the current application default format is returned for the given UnitFormatType
    Requirements
