string errorMessage = await QueuedTask.Run(async () =>
// check for selected layer
if (MapView.Active.GetSelectedLayers().Count == 0)
return "Please select a target parcel polygon layer in the table of contents.";
//get the feature layer that's selected in the table of contents
var destPolygonL = MapView.Active.GetSelectedLayers().OfType<FeatureLayer>().FirstOrDefault();
try
var myParcelFabricLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<ParcelLayer>().FirstOrDefault();
//if there is no fabric in the map then bail
if (myParcelFabricLayer == null)
return "There is no fabric in the map.";
var pRec = myParcelFabricLayer.GetActiveRecord();
if (pRec == null)
return "There is no Active Record. Please set the active record and try again.";
string ParcelTypeName = "";
IEnumerable<string> parcelTypeNames = await myParcelFabricLayer.GetParcelTypeNamesAsync();
foreach (string parcelTypeNm in parcelTypeNames)
var polygonLyrParcelTypeEnum = await myParcelFabricLayer.GetParcelPolygonLayerByTypeNameAsync(parcelTypeNm);
foreach (FeatureLayer lyr in polygonLyrParcelTypeEnum)
if (lyr == destPolygonL)
ParcelTypeName = parcelTypeNm;
break;
if (String.IsNullOrEmpty(ParcelTypeName))
var srcFeatLyr = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(l => l.Name.Contains("MySourceLines") && l.IsVisible);
if (srcFeatLyr == null)
return "Looking for a layer named 'MySourceLines' in the table of contents.";
//now get the line layer for this parcel type
var destLineLyrEnum = await myParcelFabricLayer.GetParcelLineLayerByTypeNameAsync(ParcelTypeName);
if (destLineLyrEnum.Count == 0) //make sure there is one in the map
return ParcelTypeName + " not found.";
var destLineL = destLineLyrEnum.FirstOrDefault();
if (destLineL == null || destPolygonL == null)
return "";
var editOper = new EditOperation()
Name = "Copy Line Features To Parcel Type",
ProgressMessage = "Copy Line Features To Parcel Type...",
ShowModalMessageAfterFailure = true,
SelectNewFeatures = true,
SelectModifiedFeatures = false
var ids = new List<long>((srcFeatLyr as FeatureLayer).GetSelection().GetObjectIDs());
if (ids.Count == 0)
return "No selected lines were found. Please select line features and try again.";
editOper.CopyLineFeaturesToParcelType(srcFeatLyr, ids, destLineL, destPolygonL);
if (!editOper.Execute())
return editOper.ErrorMessage;
catch (Exception ex)
return ex.Message;
return "";
if (!string.IsNullOrEmpty(errorMessage))
MessageBox.Show(errorMessage, "Copy Line Features To Parcel Type.");
