ArcGIS.Desktop.Editing.Attributes Namespace / Inspector Class / Load Method / Load(Table,IEnumerable<Int64>) Method
A table from the geodatabase.
An IEnumerable containing the object IDs to load.
    Load multiple table rows into the inspector. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void Load(
       Table table,
       IEnumerable<long> oids
    Public Overloads Sub Load( _
       ByVal table As Table, _
       ByVal oids As IEnumerable(Of Long) _
    Parameters
    table
    oids
    Exceptions
    ExceptionDescription
    Requirements
