ArcGIS.Core.CIM Namespace / CIMBAGraduatedSymbolsRendererProperties Class
Properties Methods Events
    CIMBAGraduatedSymbolsRendererProperties Class Members
    The following tables list the members exposed by CIMBAGraduatedSymbolsRendererProperties.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the classification field names in the levels of detail feature classes.
    Public Property Gets or sets the classification method.
    Public Property Gets or sets the color ramp.
    Public Property Gets or sets the maximum symbol size.
    Public Property Gets or sets the minimum symbol size.
    Public Property Gets or sets the number of breaks for classification renderer.
    Public Property Gets or sets the standard deviation multiplier. Used to compute breaks for the standard deviation classification method.
    Public Property Gets or sets the template color. Used for layers with a single variable.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMBAGraduatedSymbolsRendererProperties.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMBAGraduatedSymbolsRendererProperties with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMBAGraduatedSymbolsRendererProperties and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
