ArcGIS.Desktop.Layouts Namespace / Layout Class / BringToFront Method / BringToFront(Element) Method
The element to bring to the front
    Bring the element to the front of its parent's element collection. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void BringToFront(
       Element element
    Public Overloads Sub BringToFront( _
       ByVal element As Element _
    Parameters
    element
    Exceptions
    ExceptionDescription
    Value cannot be null: element
    elements must belong to graphicsLayer
    Remarks
    Refer to CanBringForward(Element) to check whether an element can be brought forward. Element z order can only be changed relative to its parent's element collection. The top element will have a z order of N - 1 where N is equal to the number of elements within the element parent's element collection. Check z order with Element.ZOrder.
    Requirements
