ArcGIS.Desktop.Layouts Namespace / Layout Class / SetMetadata Method
The xml formatted metadata
Example
    SetMetadata Method (Layout)
    Sets the Layout metadata. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetMetadata( _
       ByVal metadataXml As String _
    public void SetMetadata(
       string metadataXml
    Parameters
    metadataXml
    Exceptions
    ExceptionDescription
    There is a load or parse error in the XML
    Remarks
    The input xml must be a valid metadata document. The Layout metadata must be editable. Refer to GetCanEditMetadata.
    Example
    Layout Metadata
      //Note: Must be on QueuedTask.Run
      //Gets the Layout metadata.
      var layout_xml = layout.GetMetadata();
      //Can metadata be edited?
      if (layout.GetCanEditMetadata())
        //Set the metadata back
        layout.SetMetadata(layout_xml);
    Requirements
