ArcGIS.Desktop.Reports Namespace / ReportElementFactory Class / CreateFieldValueTextElement Method
IElementContainer
Envelope
CIMReportField
CIMTextSymbol
    CreateFieldValueTextElement Method (ReportElementFactory)
    Creates a field value text element on a report from an envelope geometry. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function CreateFieldValueTextElement( _
       ByVal elementContainer As IElementContainer, _
       ByVal envelope As Envelope, _
       ByVal reportField As CIMReportField, _
       Optional ByVal textSymbol As CIMTextSymbol _
    ) As GraphicElement
    Parameters
    elementContainer
    IElementContainer
    envelope
    Envelope
    reportField
    CIMReportField
    textSymbol
    CIMTextSymbol
    Return Value
    Returns a GraphicElement
    Exceptions
    ExceptionDescription
    Invalid report section.
    Invalid report.
    Element extents outside section.
    Failed to create text element.
    Remarks
    The element gets added to the group at the topmost position.
    Requirements
