ArcGIS.Core.CIM Namespace / CIMMaplexLabelStackingProperties Class
Properties Methods Events
    CIMMaplexLabelStackingProperties Class Members
    The following tables list the members exposed by CIMMaplexLabelStackingProperties.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the maximum number of characters per line.
    Public Property Gets or sets the maximum number of lines.
    Public Property Gets or sets the minimum number of characters per line.
    Public Property Gets or sets a value indicating whether to prefer to stack long labels.
    Public Property Gets or sets the stacking separators.
    Public Property Gets or sets the stacking alignment.
    Public Property Gets or sets a value indicating whether leading and trailing stacking separators are trimmed from the label string.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMMaplexLabelStackingProperties.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMMaplexLabelStackingProperties with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMMaplexLabelStackingProperties and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
