ArcGIS.Desktop.Mapping.DeviceLocation Namespace / MapDeviceLocationOptions Class
Members Example
    Represents the settings available for configuring the MapDeviceLocationService.
    Syntax
    public class MapDeviceLocationOptions
    Public Class MapDeviceLocationOptions
    Remarks
    Use the MapDeviceLocationOptions to update the current device location source with new options
    Example
    Get Current Map Device Location Options
      //Gets the current device location options used by the MapDeviceLocationService
      var options = MapDeviceLocationService.Instance.GetDeviceLocationOptions();
      //Device location visibility on the map
      var visibility = options.DeviceLocationVisibility;
      //MappingDeviceLocationNavigationMode
      var navMode = options.NavigationMode;
      //Heading of the location from the device points to the top of the screen
      var trackUp = options.TrackUpNavigation;
      //Show accuracy buffer on the map
      var showBuffer = options.ShowAccuracyBuffer;
    Set map view to always be centered on the device location
      // Get the MapDeviceLocationOptions currently used by the MapDeviceLocationService
      var currentOptions = MapDeviceLocationService.Instance.GetDeviceLocationOptions();
      if (currentOptions == null)
        return;
      // Set the device location visibility on the map to true
      currentOptions.DeviceLocationVisibility = true;
      //Set the navigation mode to keep the device location at the center of the map
      currentOptions.NavigationMode = MappingDeviceLocationNavigationMode.KeepAtCenter;
      //Sets the MapDeviceLocationOptions to be updates with these values
      await QueuedTask.Run(() =>
        MapDeviceLocationService.Instance.SetDeviceLocationOptions(currentOptions));
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.DeviceLocation.MapDeviceLocationOptions
    Requirements
