ArcGIS.Desktop.Mapping.DeviceLocation Namespace / MapDeviceLocationService Class / ZoomOrPanToCurrentLocation Method
Set to true to zoom.
    ZoomOrPanToCurrentLocation Method (MapDeviceLocationService)
    Zooms or pans the active map view to the current location, keeping the current device location at the center. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void ZoomOrPanToCurrentLocation(
       bool zoom
    Public Sub ZoomOrPanToCurrentLocation( _
       ByVal zoom As Boolean _
    Parameters
    zoom
    Exceptions
    ExceptionDescription
    The active map view cannot be null
    Remarks
    There must be an active map view with an associated map or a System.InvalidOperationException will be thrown
    Requirements
