SetDeviceLocationEnabled Method (IMapDeviceLocationService)
Enables (or disables) the current DeviceLocationSource. Use
ArcGIS.Desktop.Core.DeviceLocation.IDeviceLocationService.Open prior to enabling the DeviceLocationSource. This method must be called on the MCT. Use QueuedTask.Run.
Enable/Disable Current Device Location Source For the Map
bool enabled = MapDeviceLocationService.Instance.IsDeviceLocationEnabled;
await QueuedTask.Run(() =>
MapDeviceLocationService.Instance.SetDeviceLocationEnabled(!enabled);
