ArcGIS.Desktop.Mapping.DeviceLocation Namespace / IMapDeviceLocationService Interface
Properties Methods
    IMapDeviceLocationService Interface Members
    The following tables list the members exposed by IMapDeviceLocationService.
    Public Properties
     NameDescription
     Property Gets the enabled state of the current DeviceLocationSource.
    Top
    Public Methods
     NameDescription
     Method Gets the MapDeviceLocationOptions currently used by the MapDeviceLocationService.
     MethodEnables (or disables) the current DeviceLocationSource. Use ArcGIS.Desktop.Core.DeviceLocation.IDeviceLocationService.Open prior to enabling the DeviceLocationSource. This method must be called on the MCT. Use QueuedTask.Run.
     MethodSets a MapDeviceLocationOptions to update the current MapDeviceLocationService settings. This method must be called on the MCT. Use QueuedTask.Run.
     Method Zooms or pans the active map view to the current location, keeping the current device location at the center. This method must be called on the MCT. Use QueuedTask.Run.
    Top
