MapDeviceLocationOptions GetDeviceLocationOptions()
Function GetDeviceLocationOptions() As MapDeviceLocationOptions
//Gets the current device location options used by the MapDeviceLocationService
var options = MapDeviceLocationService.Instance.GetDeviceLocationOptions();
//Device location visibility on the map
var visibility = options.DeviceLocationVisibility;
//MappingDeviceLocationNavigationMode
var navMode = options.NavigationMode;
//Heading of the location from the device points to the top of the screen
var trackUp = options.TrackUpNavigation;
//Show accuracy buffer on the map
var showBuffer = options.ShowAccuracyBuffer;
// Get the MapDeviceLocationOptions currently used by the MapDeviceLocationService
var currentOptions = MapDeviceLocationService.Instance.GetDeviceLocationOptions();
if (currentOptions == null)
return;
// Set the device location visibility on the map to true
currentOptions.DeviceLocationVisibility = true;
//Set the navigation mode to keep the device location at the center of the map
currentOptions.NavigationMode = MappingDeviceLocationNavigationMode.KeepAtCenter;
//Sets the MapDeviceLocationOptions to be updates with these values
await QueuedTask.Run(() =>
MapDeviceLocationService.Instance.SetDeviceLocationOptions(currentOptions));
