ArcGIS.Desktop.Mapping.DeviceLocation Namespace / MapDeviceLocationService Class / SetDeviceLocationEnabled Method
Set to true to enable the current DeviceLocationSource. False to disable.
    SetDeviceLocationEnabled Method (MapDeviceLocationService)
    Enables (or disables) the current DeviceLocationSource. Use ArcGIS.Desktop.Core.DeviceLocation.IDeviceLocationService.Open prior to enabling the DeviceLocationSource. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetDeviceLocationEnabled(
       bool enable
    Public Sub SetDeviceLocationEnabled( _
       ByVal enable As Boolean _
    Parameters
    enable
    Exceptions
    ExceptionDescription
    The active map view is null.
    A DeviceLocationSource must be open.
    Remarks
    There must be an active map view with an associated map or an System.InvalidOperationException will be thrown.
    Set MapDeviceLocationOptions.DeviceLocationVisibility = true to display the location on the map view when the device location source is enabled. Refer to SetDeviceLocationOptions.
    Requirements
