var map = MapView.Active?.Map;
if (map == null)
return;
await QueuedTask.Run(() =>
//Check if the label engine is Maplex or standard.
CIMGeneralPlacementProperties labelEngine = map.GetDefinition().GeneralPlacementProperties;
if (labelEngine is CIMStandardGeneralPlacementProperties)
return;
//Get the layer's definition
var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
//Get the label classes - we need the first one
var listLabelClasses = lyrDefn.LabelClasses.ToList();
var theLabelClass = listLabelClasses.FirstOrDefault();
//Modify label Rotation
CIMMaplexRotationProperties rotationProperties = new CIMMaplexRotationProperties
Enable = true, //Enable rotation
RotationField = "ELEVATION", //Field that is used to define rotation angle
AdditionalAngle = 15, //Additional rotation
RotationType = MaplexLabelRotationType.Arithmetic,
AlignmentType = MaplexRotationAlignmentType.Perpendicular,
AlignLabelToAngle = true
theLabelClass.MaplexLabelPlacementProperties.RotationProperties = rotationProperties;
lyrDefn.LabelClasses = listLabelClasses.ToArray(); //Set the labelClasses back
featureLayer.SetDefinition(lyrDefn); //set the layer's definition
