ArcGIS.Core.CIM Namespace / CIMMaplexRotationProperties Class
Properties Methods Events
    CIMMaplexRotationProperties Class Members
    The following tables list the members exposed by CIMMaplexRotationProperties.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets additional angle to add to the data value.
    Public Property Gets or sets a value indicating whether or not to align the label to the angle.
    Public Property Gets or sets the alignment type.
    Public Property Gets or sets a value indicating whether to enable rotation.
    Public Property Gets or sets a value indicating whether to place the label perpendicular to the angle.
    Public Property Gets or sets ExpressionInfo that contains the Arcade expression that returns rotation as a number. When both RotationField and RotationExpressionInfo are present RotationExpressionInfo is used.
    Public Property Gets or sets the rotation field to get values from.
    Public Property Gets or sets the rotation type.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMMaplexRotationProperties.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMMaplexRotationProperties with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMMaplexRotationProperties and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
