ArcGIS.Core.CIM Namespace / CIMMaplexRotationProperties Class / RotationType Property
Example
    RotationType Property (CIMMaplexRotationProperties)
    Gets or sets the rotation type.
    Syntax
    public MaplexLabelRotationType RotationType {get; set;}
    Public Property RotationType As MaplexLabelRotationType
    Example
    Modify label Rotation - Point geometry
      var map = MapView.Active?.Map;
      if (map == null)
        return;
      await QueuedTask.Run(() =>
        //Check if the label engine is Maplex or standard.
        CIMGeneralPlacementProperties labelEngine = map.GetDefinition().GeneralPlacementProperties;
        if (labelEngine is CIMStandardGeneralPlacementProperties)
          return;
        //Get the layer's definition
        var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
        //Get the label classes - we need the first one
        var listLabelClasses = lyrDefn.LabelClasses.ToList();
        var theLabelClass = listLabelClasses.FirstOrDefault();
        //Modify label Rotation
        CIMMaplexRotationProperties rotationProperties = new CIMMaplexRotationProperties
          Enable = true, //Enable rotation
          RotationField = "ELEVATION", //Field that is used to define rotation angle
          AdditionalAngle = 15, //Additional rotation
          RotationType = MaplexLabelRotationType.Arithmetic,
          AlignmentType = MaplexRotationAlignmentType.Perpendicular,
          AlignLabelToAngle = true
        theLabelClass.MaplexLabelPlacementProperties.RotationProperties = rotationProperties;
        lyrDefn.LabelClasses = listLabelClasses.ToArray(); //Set the labelClasses back
        featureLayer.SetDefinition(lyrDefn); //set the layer's definition
    Requirements
