Public NotInheritable Class KnowledgeGraphDocumentDescription
public sealed class KnowledgeGraphDocumentDescription
The Create operations return a RowToken - a representation of the future or "to be" created row. Create a RowHandle with this rowToken and use with a KnowledgeGraphRelationshipDescription to create the relationship between an entity and the document row.
await QueuedTask.Run(() =>
//Instantiate an operation for the Create
var edit_op = new EditOperation()
Name = "Create a records",
SelectNewFeatures = true
// create the entity
var personToken = edit_op.Create(personLayer, personAtts);
// create the document
var kgDocDesc = new KnowledgeGraphDocumentDescription(
@"D:\Data\BirthCertificate.jpg");
var docToken = edit_op.Create(docLayer, kgDocDesc);
// create RowHandles from the returned RowTokens
var personHandle = new RowHandle(personToken);
var docHandle = new RowHandle(docToken);
// create the "hasDocument" relationship
var rd = new KnowledgeGraphRelationshipDescription(personHandle, docHandle);
edit_op.Create(docLayer, rd);
// create the provenance record for the person entity using the document entity
// provenance record is on the "name" field
var pd = new KnowledgeGraphProvenanceDescription(
personHandle, "name", docHandle, "", "comments");
edit_op.Create(pd);
// execute - create all the entities and relationship rows _together_
edit_op.Execute();
using (var kg_for_doc = kgLayer.GetDatastore())
var propInfo = kg_for_doc.GetPropertyNameInfo();
if (!propInfo.SupportsDocuments)
return false;
Name = "Create Document Example",
var doc_entity_name = propInfo.DocumentTypeName;
var hasdoc_rel_name = GetHasDocumentTypeName(kg.GetDataModel());
//Document can also be FeatureClass
var doc_tbl = kg_for_doc.OpenDataset<Table>(doc_entity_name);
var doc_rel_tbl = kg_for_doc.OpenDataset<Table>(hasdoc_rel_name);
//This is the document to be added...file, image, resource, etc.
var doc_url = @"E:\Data\Temp\HelloWorld.txt";
// create the KnowledgeGraphDocumentDescription
var kgDocDesc = new KnowledgeGraphDocumentDescription(doc_url);
// if there is a geometry use the following ctor
// var kgDocDesc = new KnowledgeGraphDocumentDescription(doc_url, doc_location);
// if you have additional custom attributes
//var customDocAtts = new Dictionary<string, object>();
//customDocAtts.Add("custom_attrib", "Foo");
//customDocAtts.Add("custom_attrib2", "Bar");
//var kgDocDesc = new KnowledgeGraphDocumentDescription(url, null, customDocAtts);
// add additional properties if required
kgDocDesc.Keywords = @"text,file,example";
// The Create method will auto-populate the Url, Name, FileExtension and contentType fields of the document row
// from the path supplied.
var rowToken = edit_op.Create(doc_tbl, kgDocDesc);
//Get the entity whose document this is...
var org_fc = kg_for_doc.OpenDataset<FeatureClass>("Organization");
var qf = new ArcGIS.Core.Data.QueryFilter()
WhereClause = "name = 'Acme'",
SubFields = "*"
var origin_org_id = Guid.Empty;
using (var rc = org_fc.Search(qf))
if (!rc.MoveNext())
return false;
origin_org_id = rc.Current.GetGlobalID();//For the relate
// set up the row handles
var originHandle = new RowHandle(org_fc, origin_org_id); // entity
var destinationHandle = new RowHandle(rowToken); // document
// create the KnowledgeGraphRelationshipDescription
var rd = new KnowledgeGraphRelationshipDescription(originHandle, destinationHandle);
// if you have additional custom attributes for the "HasDocument" relationship
//var customHasDocAtts = new Dictionary<string, object>();
//customHasDocAtts.Add("custom_attrib", "Foo");
//customHasDocAtts.Add("custom_attrib2", "Bar");
//var rd = new KnowledgeGraphRelationshipDescription(originHandle, destinationHandle, customHasDocAtts);
// create the relate record using the same edit operation
edit_op.Create(doc_rel_tbl, rd);
//Call execute to create all the entities and relationship rows _together_
return edit_op.Execute();
System.Object
ArcGIS.Desktop.Editing.KnowledgeGraphDocumentDescription
