ArcGIS.Desktop.KnowledgeGraph Namespace / KnowledgeGraphInvestigation Class
Members Example
    Represents a Knowledge Graph investigation in a project and provides access to the entities, relationships and other items in the knowledge graph.
    Object Model
    KnowledgeGraphInvestigation ClassCIMWorkspaceConnection ClassCIMFilteredFindPathsConfiguration ClassCIMKnowledgeGraphQueryDefinition ClassOperationManager Class
    Syntax
    Public NotInheritable Class KnowledgeGraphInvestigation
    public sealed class KnowledgeGraphInvestigation
    Remarks
    To create a KnowledgeGraphInvestigation, you must call a create method of the KnowledgeGraphInvestigationFactory class.
    To open a KnowledgeGraphInvestigation, use the ProApp.Panes.CreateInvestigationPane method.
    You need to use a KnowledgeGraphInvestigationView to interact with a KnowledgeGraphInvestigation. Multiple KnowledgeGraphInvestigationViews can be opened for a KnowledgeGraphInvestigation at a given time, but there can only be one active KnowledgeGraphInvestigationView which is returned by the KnowledgeGraphInvestigation.Active static member. Use the KnowledgeGraphInvestigation property to access the KnowledgeGraphInvestigation object associated with the KnowledgeGraphInvestigationView.
    Example
    Create an Investigation
      await QueuedTask.Run(() =>
        var investigation = KnowledgeGraphInvestigationFactory.Instance.CreateInvestigation(url, "myInvestigation");
        //TODO - use the investigation
    Create and open an investigation pane
        ProApp.Panes.CreateInvestigationPaneAsync(investigation);
    Open an existing investigation
      // open an existing investigation
      var investigationProjectItems = Project.Current.GetItems<KnowledgeGraphInvestigationProjectItem>();
      var investigationProjectItem = investigationProjectItems.FirstOrDefault(ipi => ipi.Name.Equals("myInvestigation"));
        KnowledgeGraphInvestigation investigation = investigationProjectItem.GetInvestigation();
        // or
        investigation.OpenViewAsync();
      // or
      investigationProjectItem.OpenInvestigationPaneAsync();
    Get the panes for an investigation
        var panes = investigation.GetInvestigationPanes();
        foreach (var pane in panes)
          KnowledgeGraphInvestigationView kgView = pane.InvestigationView;
          // if it's the active investigation view
          if (kgView == KnowledgeGraphInvestigationView.Active)
            // do something
    Get the active KnowledgeGraphInvestigationView, KnowledgeGraphInvestigation
      // access the currently active knowledge graph investigation view
      KnowledgeGraphInvestigationView activeView = KnowledgeGraphInvestigationView.Active;
      KnowledgeGraphInvestigation investigation = activeView?.Investigation;
      if (investigation != null)
        // perform some action
    Activate an existing investigation view
      //Confirm if investigation exists as a project item
      KnowledgeGraphInvestigationProjectItem investigationItem =
         Project.Current.GetItems<KnowledgeGraphInvestigationProjectItem>().FirstOrDefault(
                                                            item => item.Name.Equals("myInvestigation"));
      if (investigationItem != null)
           await QueuedTask.Run(() => investigationItem.GetInvestigation());
        // see if a view is already open that references the same investigation
        foreach (var investigationPane in ProApp.Panes.OfType<IKnowledgeGraphInvestigationPane>())
          //if there is a match, activate the view
          if (investigationPane.InvestigationView.Investigation == investigation)
            (investigationPane as Pane).Activate();
            return;
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.KnowledgeGraph.KnowledgeGraphInvestigation
    Requirements
    ArcGIS Pro version: 3.5 or higher.
