ArcGIS.Desktop.KnowledgeGraph Namespace / KnowledgeGraphInvestigationView Class
Members Example
    Represents the view of a Knowledge Graph investigation in a pane.
    Object Model
    KnowledgeGraphInvestigationView ClassKnowledgeGraphInvestigationView ClassSearchOptions ClassKnowledgeGraphLayerIDSet ClassKnowledgeGraphInvestigation ClassKnowledgeGraphLayerIDSet Class
    Syntax
    Public NotInheritable Class KnowledgeGraphInvestigationView
    public sealed class KnowledgeGraphInvestigationView
    Remarks
    A project can contain multiple investigations. An investigation view is simply a view of an investigation. The KnowledgeGraphInvestigationView class provides methods and properties to navigate and interact with items in the investigation. The investigation being visualized in the view can be accessed via the Investigation property.
    There can be multiple investigation views open at a given time, but there can only be one active investigation view. The active investigation view will set the context for the ribbon and many of the dock panes in the application. For example, the Contents pane will reflect the items of the active investigation view's investigation. The instance of the active investigation view can be accessed via the static the Active property. The property will return null if there is no active investigation view.
    The investigation view also provides the context for managing selected items in the Contents pane. For example, the GetSelectedEntities method returns a collection of entities that are currently selected in the Contents pane.
    Example
    Get the active KnowledgeGraphInvestigationView, KnowledgeGraphInvestigation
      // access the currently active knowledge graph investigation view
      KnowledgeGraphInvestigationView activeView = KnowledgeGraphInvestigationView.Active;
      KnowledgeGraphInvestigation investigation = activeView?.Investigation;
      if (investigation != null)
        // perform some action
    Activate an existing investigation view
      //Confirm if investigation exists as a project item
      KnowledgeGraphInvestigationProjectItem investigationItem =
         Project.Current.GetItems<KnowledgeGraphInvestigationProjectItem>().FirstOrDefault(
                                                            item => item.Name.Equals("myInvestigation"));
      if (investigationItem != null)
           await QueuedTask.Run(() => investigationItem.GetInvestigation());
        // see if a view is already open that references the same investigation
        foreach (var investigationPane in ProApp.Panes.OfType<IKnowledgeGraphInvestigationPane>())
          //if there is a match, activate the view
          if (investigationPane.InvestigationView.Investigation == investigation)
            (investigationPane as Pane).Activate();
            return;
    Select entity, relationship types in an investigation view
      // get the active investigation view
      var iv = KnowledgeGraphInvestigationView.Active;
      // clear any TOC selection
      iv.ClearTOCSelection();
      // select entities
      List<string> entities = new List<string>();
      entities.Add("Person");
      entities.Add("Org");
      iv.SelectEntities(entities);
      // or select relationships
      List<string> relationships = new List<string>();
      relationships.Add("HasEmployee");
      iv.SelectRelationships(relationships);
      // or select a combination
      List<string> namedObjectTypes = new List<string>();
      namedObjectTypes.Add("Person");
      namedObjectTypes.Add("Org");
      namedObjectTypes.Add("HasEmployee");
      iv.SelectNamedObjectTypes(namedObjectTypes);
    Select records in an investigation view
      var serviceUri = iv.Investigation.ServiceUri;
      // build a dictionary of records
      string some_entity = "Entity_Type_Name";
      var dict = new Dictionary<string, List<long>>();
      //Each entry consists of the type name and corresponding lists of ids
      dict.Add(some_entity, new List<long>() { 1, 5, 18, 36, 78 });
      //Create the id set...
      var idSet = KnowledgeGraphLayerIDSet.FromDictionary(new Uri(serviceUri), dict);
      // select the records on the investigation view
      iv.SetSelectedRecords(idSet, SelectionCombinationMethod.New);
    Clear selected records in an investigation view
      // clear the selected records
      iv.ClearSelectedRecords();
    Get Selected records and open in a new link chart
        // get the investigation
        var inv = iv.Investigation;
        // get the set of selected records
        var idSet = iv.GetSelectedRecords();
        // view these records in a link chart
        var map = MapFactory.Instance.CreateLinkChart("myLinkChart", new Uri(inv.ServiceUri), idSet);
        ProApp.Panes.CreateMapPaneAsync(map);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.KnowledgeGraph.KnowledgeGraphInvestigationView
    Requirements
    ArcGIS Pro version: 3.5 or higher.
