ArcGIS.Desktop.KnowledgeGraph Namespace / KnowledgeGraphInvestigationView Class / Investigation Property
Example
    Gets the Knowledge Graph investigation associated with the investigation view.
    Syntax
    Public ReadOnly Property Investigation As KnowledgeGraphInvestigation
    public KnowledgeGraphInvestigation Investigation {get;}
    Example
    Get the active KnowledgeGraphInvestigationView, KnowledgeGraphInvestigation
      // access the currently active knowledge graph investigation view
      KnowledgeGraphInvestigationView activeView = KnowledgeGraphInvestigationView.Active;
      KnowledgeGraphInvestigation investigation = activeView?.Investigation;
      if (investigation != null)
        // perform some action
    Get Selected records and open in a new link chart
      // get the active investigation view
      var iv = KnowledgeGraphInvestigationView.Active;
      await QueuedTask.Run(() =>
        // get the investigation
        var inv = iv.Investigation;
        // get the set of selected records
        var idSet = iv.GetSelectedRecords();
        // view these records in a link chart
        var map = MapFactory.Instance.CreateLinkChart("myLinkChart", new Uri(inv.ServiceUri), idSet);
        ProApp.Panes.CreateMapPaneAsync(map);
    Requirements
    ArcGIS Pro version: 3.5 or higher.
