ArcGIS.Desktop.KnowledgeGraph Namespace / KnowledgeGraphInvestigation Class / GetInvestigationPanes Method
Example
    Get the collection of investigation panes for the investigation.
    Syntax
    Return Value
    Example
    Get the panes for an investigation
      // open an existing investigation
      var investigationProjectItems = Project.Current.GetItems<KnowledgeGraphInvestigationProjectItem>();
      var investigationProjectItem = investigationProjectItems.FirstOrDefault(ipi => ipi.Name.Equals("myInvestigation"));
      await QueuedTask.Run(() =>
        KnowledgeGraphInvestigation investigation = investigationProjectItem.GetInvestigation();
        var panes = investigation.GetInvestigationPanes();
        foreach (var pane in panes)
          KnowledgeGraphInvestigationView kgView = pane.InvestigationView;
          // if it's the active investigation view
          if (kgView == KnowledgeGraphInvestigationView.Active)
            // do something
    Requirements
    ArcGIS Pro version: 3.5 or higher.
