ArcGIS.Desktop.KnowledgeGraph Namespace / IKnowledgeGraphInvestigationPane Interface
Members Example
    Represents a pane which contains a Knowledge Graph investigation view. See KnowledgeGraphInvestigationView.
    Object Model
    IKnowledgeGraphInvestigationPane InterfaceKnowledgeGraphInvestigationView ClassCIMView Class
    Syntax
    Public Interface IKnowledgeGraphInvestigationPane
    public interface IKnowledgeGraphInvestigationPane
    Example
    Get the panes for an investigation
      // open an existing investigation
      var investigationProjectItems = Project.Current.GetItems<KnowledgeGraphInvestigationProjectItem>();
      var investigationProjectItem = investigationProjectItems.FirstOrDefault(ipi => ipi.Name.Equals("myInvestigation"));
      await QueuedTask.Run(() =>
        KnowledgeGraphInvestigation investigation = investigationProjectItem.GetInvestigation();
        var panes = investigation.GetInvestigationPanes();
        foreach (var pane in panes)
          KnowledgeGraphInvestigationView kgView = pane.InvestigationView;
          // if it's the active investigation view
          if (kgView == KnowledgeGraphInvestigationView.Active)
            // do something
    Activate an existing investigation view
      //Confirm if investigation exists as a project item
      KnowledgeGraphInvestigationProjectItem investigationItem =
         Project.Current.GetItems<KnowledgeGraphInvestigationProjectItem>().FirstOrDefault(
                                                            item => item.Name.Equals("myInvestigation"));
      if (investigationItem != null)
           await QueuedTask.Run(() => investigationItem.GetInvestigation());
        // see if a view is already open that references the same investigation
        foreach (var investigationPane in ProApp.Panes.OfType<IKnowledgeGraphInvestigationPane>())
          //if there is a match, activate the view
          if (investigationPane.InvestigationView.Investigation == investigation)
            (investigationPane as Pane).Activate();
            return;
    Requirements
    ArcGIS Pro version: 3.5 or higher.
