ArcGIS.Desktop.Presentations Namespace / Presentation Class / AddMapPage Method / AddMapPage(Bookmark,Int32) Method
Bookmark
The insert position. If -1, the page is added to the end of the page collection. If 0, the page is added to the beginning of the page collection.
Example
    Adds a new map page to the presentation based on a bookmark. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function AddMapPage( _
       ByVal bookmark As Bookmark, _
       ByVal insertIndex As Integer _
    ) As MapPresentationPage
    Parameters
    bookmark
    Bookmark
    insertIndex
    Return Value
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Example
    Map page
      //Note: Must be on QueuedTask
      // retrieve a map from the project based on the map name
      MapProjectItem mpi = Project.Current.GetItems<MapProjectItem>()
                                 .FirstOrDefault(m => m.Name.Equals("Your Map Name", StringComparison.CurrentCultureIgnoreCase));
      Map map = mpi.GetMap();
      //create a map page using map's default extent
      presentation.AddMapPage(map, -1);
      //create a page using map's bookmark
      Bookmark bookmark = map.GetBookmarks().FirstOrDefault(
                   b => b.Name == "Your bookmark"); // get the bookmark based on the bookmark's name
      presentation.AddMapPage(bookmark, -1);
    Requirements
    ArcGIS Pro version: 3.5 or higher.
