ArcGIS.Desktop.Presentations Namespace / Presentation Class / Export Method
ExportFormat
PresentationExportOptions
Example
    Export Method (Presentation)
    Exports the presentation to a variety of formats (e.g., PDF, video, image series). This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Remarks
    When there are more than one page to export and the export format is image (e.g., JPEGFormat or PNGFormat), the presentation will be exported to an image sequence. The file name of each image in an image sequence comprises four parts: (1) the base name of exportFormat.OutputFileName stripped of extension; (2) an underscore ("_"); (3) the page index; (4) the image extension (e.g., .png). Examples: test_1.png, test_3.png, test_5.png.
    Example
    Export a layout to PDF
      //Export a single page layout to PDF.
      //Create a PDF format with appropriate settings
      //BMP, EMF, EPS, GIF, JPEG, PNG, SVG, TGA, and TFF formats are also available for export
      string filePath = @"Path and file name for the output export file";
      PDFFormat PDF = new PDFFormat()
        OutputFileName = filePath,
        Resolution = 300,
        DoCompressVectorGraphics = true,
        DoEmbedFonts = true,
        HasGeoRefInfo = true,
        ImageCompression = ImageCompression.Adaptive,
        ImageQuality = ImageQuality.Best,
        LayersAndAttributes = LayersAndAttributes.LayersAndAttributes
      //Check to see if the path is valid and export
      if (PDF.ValidateOutputFilePath())
        //Note: Must be on QueuedTask.Run
        layout.Export(PDF);  //Export the layout to PDF on the worker thread
    Export a map frame to JPG
      //Export a map frame to JPG.
      //Create JPEG format with appropriate settings
      //BMP, EMF, EPS, GIF, PDF, PNG, SVG, TGA, and TFF formats are also available for export
      JPEGFormat JPG = new JPEGFormat()
        HasWorldFile = true,
        Resolution = 300,
        ColorMode = JPEGColorMode.TwentyFourBitTrueColor,
        Height = 800,
        Width = 1200
      //Reference the map frame
      MapFrame mf = layout.FindElement("MyMapFrame") as MapFrame;
      //Export on the worker thread
      //Note: Must be on QueuesTask.Run
      if (JPG.ValidateOutputFilePath())
        mf.Export(JPG);  //Export the map frame to JPG
    Export the map view associated with a map frame to BMP
      //Export the map view associated with a map frame to BMP.
      //Create BMP format with appropriate settings
      //EMF, EPS, GIF, JPEG, PDF, PNG, SVG, TGA, and TFF formats are also available for export
      BMPFormat BMP = new BMPFormat()
        Resolution = 300,
        Height = 500,
        Width = 800,
      await QueuedTask.Run(() =>
        MapView mv_bmp = mapFrame.GetMapView(layoutView);
        if (mv_bmp != null)
          if (BMP.ValidateOutputFilePath())
            mv_bmp.Export(BMP);  //Export to BMP
    Export a map series to single PDF
      //Export a map series with multiple pages to a single PDF.
      //Create PDF format with appropriate settings
      PDFFormat MS_PDF = new PDFFormat()
        Resolution = 300,
      //Set up map series export options
      MapSeriesExportOptions MS_ExportOptions = new MapSeriesExportOptions()
        ExportPages = ExportPages.Custom,  //Provide a specific list of pages
        CustomPages = "1-3, 5",  //Only used if ExportPages.Custom is set
        ExportFileOptions = ExportFileOptions.ExportAsSinglePDF,  //Export all pages to a single, multi-page PDF
        ShowSelectedSymbology = false  //Do no show selection symbology in the output
      if (MS_PDF.ValidateOutputFilePath())
        layout.Export(MS_PDF, MS_ExportOptions);  //Export to PDF
    Export a map series to individual TIFF files
      //Export each page of a map series to an individual TIFF file.
      //Create TIFF format with appropriate settings
      TIFFFormat TIFF = new TIFFFormat()
        Resolution = 300,
        ColorMode = TIFFColorMode.TwentyFourBitTrueColor,
        HasGeoTiffTags = true,
        ImageCompression = TIFFImageCompression.LZW
      MapSeriesExportOptions MSExportOptions_TIFF = new MapSeriesExportOptions()
        ExportPages = ExportPages.All,  //All pages
        ExportFileOptions = ExportFileOptions.ExportMultipleNames,  //Export each page to an individual file using page name as a suffix.
        ShowSelectedSymbology = true  //Include selection symbology in the output
      //Note: Must be on the QueuedTask.Run()
      if (TIFF.ValidateOutputFilePath())
        layout.Export(TIFF, MSExportOptions_TIFF);  //Export to TIFF
    Export a presentation
      //Note: Call within QueuedTask.Run()
      //Create mp4 format with appropriate settings
      MP4VideoFormat mp4Format = new MP4VideoFormat();
      mp4Format.Width = 800;
      mp4Format.Height = 600;
      mp4Format.OutputFileName = @"my folder\presentation.mp4";
      //Define Export Options
      PresentationExportOptions options = new PresentationExportOptions
        PageRangeOption = ExportPageOptions.ExportByPageRange,
        CustomPages = "1,2,8"
      //export as mp4
      presentation.Export(mp4Format, options);
    Requirements
    ArcGIS Pro version: 3.5 or higher.
