ArcGIS.Desktop.Presentations Namespace / PresentationElementFactory Class / CreateGroupElement Method
The parent element container. It can be a presentation page or a group element that is associated with a presentation page.
The collection of elements to be grouped (optional)
An element name (optional)
Select after create flag (default is true) (optional)
Additional element properties (optional)
Example
    CreateGroupElement Method (PresentationElementFactory)
    Creates a group element from the input element collection and element properties.
    Syntax
    Public Function CreateGroupElement( _
       ByVal elementContainer As IElementContainer, _
       Optional ByVal elements As IEnumerable(Of Element), _
       Optional ByVal elementName As String, _
       Optional ByVal select As Boolean, _
       Optional ByVal groupElementInfo As ElementInfo _
    ) As GroupElement
    Parameters
    elementContainer
    elements
    elementName
    select
    groupElementInfo
    Return Value
    Remarks
    Only elements contained within the provided elementContainer will be added to the group element. If elements is null or an empty collection then an empty GroupElement will be created.
    Example
    Create elements on a presentation page
      //Note: Must be on QueuedTask
      //create a picture element
      var imgPath = @"https://www.esri.com/content/dam/esrisites/en-us/home/" +
       "homepage-tile-podcast-business-resilience-climate-change.jpg";
      //Build a geometry to place the picture
      Coordinate2D ll = new Coordinate2D(3.5, 1);
      Coordinate2D ur = new Coordinate2D(6, 5);
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
      //create a picture element on the page
      var gElement = PresentationElementFactory.Instance.CreatePictureGraphicElement(page, env, imgPath);
      //create a text element
      //Set symbology, create and add element to a presentation page
      CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
                    ColorFactory.Instance.RedRGB, 15, "Arial", "Regular");
      //use ElementInfo to set placement properties
      var elemInfo = new ElementInfo()
        Anchor = Anchor.CenterPoint,
        Rotation = 45
      string textString = "My text";
      var textPos = new Coordinate2D(5, 3).ToMapPoint();
      var tElement = PresentationElementFactory.Instance.CreateTextGraphicElement(page,
        TextType.PointText, textPos, sym, textString, "telement", false, elemInfo);
      //create a group element with elements created above
      var elmList = new List<Element> { gElement, tElement };
      GroupElement grp1 = PresentationElementFactory.Instance.CreateGroupElement(page, elmList, "My Group");
    Requirements
    ArcGIS Pro version: 3.5 or higher.
