ArcGIS.Desktop.Presentations Namespace / PresentationElementFactory Class / CreateTextGraphicElement Method
The parent element container. It can be a presentation page or a group element that is associated with a presentation page.
The type of text graphic to create
The geometry for the resulting graphic
The text symbol to be used with the graphic (optional)
The text string (optional)
An element name (optional)
Select after create flag (default is true) (optional)
Additional element properties (optional)
Example
    CreateTextGraphicElement Method (PresentationElementFactory)
    Creates a text graphic based on the input geometry, symbol, and text and other optional parameters.
    Syntax
    Public Function CreateTextGraphicElement( _
       ByVal elementContainer As IElementContainer, _
       ByVal textType As TextType, _
       ByVal geometry As Geometry, _
       Optional ByVal textSymbol As CIMTextSymbol, _
       Optional ByVal text As String, _
       Optional ByVal elementName As String, _
       Optional ByVal select As Boolean, _
       Optional ByVal elementInfo As ElementInfo _
    ) As GraphicElement
    Parameters
    elementContainer
    textType
    geometry
    textSymbol
    text
    elementName
    select
    elementInfo
    Return Value
    Remarks
    For:
    • TextType.PointText use a point
    • TextType.SplinedText use a polyline (straight or curved)
    • TextType.CircleParagraph use a circle (polygon) or point
    • TextType.EllipseParagraph use an ellipse (polygon) or point
    • TextType.RectangleParagraph use an envelope or point
    • TextType.PolygonParagraph use a polygon or point
    If a point is used as the input for the paragraph text types, a default element extent is applied. if you want to use a text graphic previously created, eg via:
    Example
    Create elements on a presentation page
      //Note: Must be on QueuedTask
      //create a picture element
      var imgPath = @"https://www.esri.com/content/dam/esrisites/en-us/home/" +
       "homepage-tile-podcast-business-resilience-climate-change.jpg";
      //Build a geometry to place the picture
      Coordinate2D ll = new Coordinate2D(3.5, 1);
      Coordinate2D ur = new Coordinate2D(6, 5);
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
      //create a picture element on the page
      var gElement = PresentationElementFactory.Instance.CreatePictureGraphicElement(page, env, imgPath);
      //create a text element
      //Set symbology, create and add element to a presentation page
      CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
                    ColorFactory.Instance.RedRGB, 15, "Arial", "Regular");
      //use ElementInfo to set placement properties
      var elemInfo = new ElementInfo()
        Anchor = Anchor.CenterPoint,
        Rotation = 45
      string textString = "My text";
      var textPos = new Coordinate2D(5, 3).ToMapPoint();
      var tElement = PresentationElementFactory.Instance.CreateTextGraphicElement(page,
        TextType.PointText, textPos, sym, textString, "telement", false, elemInfo);
      //create a group element with elements created above
      var elmList = new List<Element> { gElement, tElement };
      GroupElement grp1 = PresentationElementFactory.Instance.CreateGroupElement(page, elmList, "My Group");
    Requirements
    ArcGIS Pro version: 3.5 or higher.
