ArcGIS.Desktop.Presentations Namespace / PresentationPageFactory Class / CreateMapPage Method / CreateMapPage(Presentation,Map,Int32) Method
The presentation
A map
The insert position. If -1, the page is added to the end of the page collection. If 0, the page is added to the beginning of the page collection.
    Adds a new map page to the presentation based on a map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function CreateMapPage( _
       ByVal presentation As Presentation, _
       ByVal map As Map, _
       Optional ByVal insertIndex As Integer _
    ) As MapPresentationPage
    Parameters
    presentation
    The presentation
    map
    A map
    insertIndex
    Return Value
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Requirements
    ArcGIS Pro version: 3.5 or higher.
