ArcGIS.Desktop.Presentations Namespace / PresentationProjectItem Class
Members Example
    Presentation project item
    Object Model
    PresentationProjectItem ClassPresentation ClassTimeInstant Class
    Syntax
    Public NotInheritable Class PresentationProjectItem
       Inherits ArcGIS.Desktop.Internal.Core.ProjectItem
       Implements ArcGIS.Desktop.Core.IMetadata, ArcGIS.Desktop.Core.IProjectItem, System.ComponentModel.INotifyPropertyChanged
    public sealed class PresentationProjectItem : ArcGIS.Desktop.Internal.Core.ProjectItem, ArcGIS.Desktop.Core.IMetadata, ArcGIS.Desktop.Core.IProjectItem, System.ComponentModel.INotifyPropertyChanged
    Example
    Gets all the presentation items in the current project
      var projectPresentations = Project.Current.GetItems<PresentationProjectItem>();
      foreach (var projectItem in projectPresentations)
        //Do Something with the presentation
    Reference an existing presentation
      //Reference a presentation associated with an active presentation view
      PresentationView associatedPresentationView = PresentationView.Active;
      if (activePresentationView != null)
        Presentation presentationExisting = activePresentationView.Presentation;
    Get a specific presentation
      PresentationProjectItem presentationProjItem = Project.Current.GetItems<PresentationProjectItem>().FirstOrDefault(item => item.Name.Equals(presentationName));
      Presentation presentationFromItem = presentationProjItem?.GetPresentation();
    Open a presentation project item in a new view
      //Open a presentation project item in a new view.
      //A presentation project item may exist but it may not be open in a view.
      //Reference a presentation project item by name
      PresentationProjectItem presentationPrjItem = Project.Current.GetItems<PresentationProjectItem>().FirstOrDefault(item => item.Name.Equals(presentationName));
      //Get the presentation associated with the presentation project item
      //Note: Must be within QueuedTask.Run
      Presentation presentationToOpen = presentationPrjItem.GetPresentation();
      //Create the new pane
      IPresentationPane iNewPresentationPane = await ProApp.Panes.CreatePresentationPaneAsync(presentationToOpen); //GUI thread
    Activate a presentation view
      //Assume we want to open a view for a particular presentation or activate a view if one is already open
      //A presentation project item is an item that appears in the Presentation folder in the Catalog pane.
      PresentationProjectItem presentationItem = Project.Current.GetItems<PresentationProjectItem>()
                                                 .FirstOrDefault(item => item.Name.Equals("Presentation Name"));
      //Note: Must be on QueuedTask.Run
      //Reference a presentation associated with a presentation project item
      if (presentationItem != null)
        //Get the presentation associated with the presentationItem
        Presentation presentationToOpen = presentationItem.GetPresentation();
        //Next check to see if a presentation view is already open that references the presentation
        foreach (var pane in ProApp.Panes)
          var prePane = pane as IPresentationPane;
          if (prePane == null)  // Not a presentation view, continue to the next pane
            continue;
          //if there is a match, activate the view
          if (prePane.PresentationView.Presentation == presentationToOpen)
            (prePane as Pane).Activate();
            return;
        //No pane found, activate a new one - must be called on UI
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
          ArcGIS.Desktop.Core.Item
                ArcGIS.Desktop.Presentations.PresentationProjectItem
    Requirements
    ArcGIS Pro version: 3.5 or higher.
