ArcGIS.Desktop.Mapping Namespace / ImageServiceLayer Class / GetSelection Method
    GetSelection Method (ImageServiceLayer)
    Gets the current selection of the image service layer. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Selection GetSelection()
    Public Function GetSelection() As Selection
    Exceptions
    ExceptionDescription
    Remarks
    This method only works with ObjectID-based selections. Null is returned if the layer does not support selection (see SupportsSelection).
    To ensure maximum robustness, callers should explicitly dispose of the returned ArcGIS.Core.Data.Selection in either a using statement or a finally block.
    Requirements
    ArcGIS Pro version: 3.5 or higher.
