ArcGIS.Core.CIM Namespace / CIMFilteredFindPathsConfiguration Class / ClosedPathPolicy Property
Example
    Gets or sets the closed path policy, i.e whether we allow, forbid, or require that the start and end vertices of a path are equal. When the value is KGClosedPathPolicy.Require, the DestinationEntities field is ignored and destinations entities are the same as origin entities.
    Syntax
    Public Property ClosedPathPolicy As KGClosedPathPolicy
    public KGClosedPathPolicy ClosedPathPolicy {get; set;}
    Example
    Run FFP Using Defaults
      //using ArcGIS.Core.Data.Knowledge.Extensions;
      await QueuedTask.Run(() =>
        var ffp_config = new CIMFilteredFindPathsConfiguration();
        ffp_config.Name = "Run FFP Using Defaults";
        //Origin Entities
        var originEntities = new List<CIMFilteredFindPathsEntity>();
        var poi_entity = new CIMFilteredFindPathsEntity();
        poi_entity.EntityTypeName = "POI";//All entities of entity type "POI"
        poi_entity.PropertyFilterPredicate = "";
        originEntities.Add(poi_entity);
        //Add the CIMFilteredFindPathsEntity to the OriginEntities collection
        ffp_config.OriginEntities = originEntities.ToArray();
        //Destination Entities
        var destEntities = new List<CIMFilteredFindPathsEntity>();
        var supp_entity = new CIMFilteredFindPathsEntity();
        supp_entity.EntityTypeName = "Supplier";//All entities of entity type "Supplier"
        supp_entity.PropertyFilterPredicate = "";
        destEntities.Add(supp_entity);
        //Add the CIMFilteredFindPathsEntity to the DestinationEntities collection
        ffp_config.DestinationEntities = destEntities.ToArray();
        //Path Filters
        ffp_config.PathFilters = [];//Empty
                                    //Traversal
        ffp_config.TraversalDirections = [];//Empty
        //Other
        ffp_config.RelationshipCostProperty = "";
        ffp_config.DefaultRelationshipCost = 1.0;
        ffp_config.DefaultTraversalDirectionType = KGTraversalDirectionType.Any;
        ffp_config.EntityUsage = FilteredFindPathsEntityUsage.AnyOriginAnyDestination;
        ffp_config.PathMode = KGPathMode.Shortest;
        ffp_config.MinPathLength = (int)1;//Min number of relationships in path
        ffp_config.MaxPathLength = (int)8;//Max number of relationships in path
        ffp_config.MaxCountPaths = (int)100000;//Total number of paths to return
        ffp_config.ClosedPathPolicy = KGClosedPathPolicy.Forbid;
        ffp_config.TimeFilter = null;
        var results = kg.RunFilteredFindPaths(ffp_config);
        //TODO process/analyze results
    Requirements
    ArcGIS Pro version: 3.6 or higher.
