ArcGIS.Core.CIM Namespace / CIMKnowledgeGraphCentralityConfiguration Class / DefaultRelationshipImportance Property
Example
    DefaultRelationshipImportance Property (CIMKnowledgeGraphCentralityConfiguration)
    Gets or sets the default importance of a relationship.
    Syntax
    Public Property DefaultRelationshipImportance As Double
    public double DefaultRelationshipImportance {get; set;}
    Example
    Configure Centrality
      //using ArcGIS.Core.Data.Knowledge.Extensions;
      await QueuedTask.Run(() =>
        //using(var kg = ....) {
        //configure centrality with custom settings
        var kg_config = new CIMKnowledgeGraphCentralityConfiguration()
          RelationshipsInterpretation = CentralityRelationshipInterpretation.Directed,
          MultiedgeFactor = 1.0,//cumulative importance
          Normalization = CentralityScoresNormalization.None,
          DefaultRelationshipCost = 1.0,
          DefaultRelationshipImportance = 1.0,
          RelationshipCostProperty = string.Empty,
          RelationshipImportanceProperty = string.Empty
        //include all entities from the kg in the subgraph
        //(no filters)
        var kg_subgraph = new CIMKnowledgeGraphSubGraph();
        //include the relevant centrality measures
        CentralityMeasure[] measures = [
          CentralityMeasure.Degree,
    CentralityMeasure.InDegree,
    CentralityMeasure.OutDegree,
    CentralityMeasure.Betweenness,
    CentralityMeasure.Closeness,
    CentralityMeasure.Harmonic,
    CentralityMeasure.Eigenvector,
    CentralityMeasure.PageRank
        //Note: CentralityMeasure.Coreness cannot be calculated
        //with directed relationships, so it is not included here.
        //Specfying Coreness (with directed or reveresed relationships) will
        //throw an exception
        //compute centrality
        var kg_centrality_results = kg.ComputeCentrality(
                                          kg_config, kg_subgraph, measures);
        //TODO process results
    Requirements
    ArcGIS Pro version: 3.6 or higher.
