ArcGIS.Core.CIM Namespace / CIMKnowledgeGraphCentralityConfiguration Class / RelationshipImportanceProperty Property
Example
    RelationshipImportanceProperty Property (CIMKnowledgeGraphCentralityConfiguration)
    Gets or sets the property defining the importance of a relationship. When the string is empty, or the property doesn't exist, or the property value is null, the default relationship importance is used instead. Negative property values are ignored and replaced by zero.
    Syntax
    Public Property RelationshipImportanceProperty As String
    public string RelationshipImportanceProperty {get; set;}
    Example
    Configure Centrality
      //using ArcGIS.Core.Data.Knowledge.Extensions;
      await QueuedTask.Run(() =>
        //using(var kg = ....) {
        //configure centrality with custom settings
        var kg_config = new CIMKnowledgeGraphCentralityConfiguration()
          RelationshipsInterpretation = CentralityRelationshipInterpretation.Directed,
          MultiedgeFactor = 1.0,//cumulative importance
          Normalization = CentralityScoresNormalization.None,
          DefaultRelationshipCost = 1.0,
          DefaultRelationshipImportance = 1.0,
          RelationshipCostProperty = string.Empty,
          RelationshipImportanceProperty = string.Empty
        //include all entities from the kg in the subgraph
        //(no filters)
        var kg_subgraph = new CIMKnowledgeGraphSubGraph();
        //include the relevant centrality measures
        CentralityMeasure[] measures = [
          CentralityMeasure.Degree,
    CentralityMeasure.InDegree,
    CentralityMeasure.OutDegree,
    CentralityMeasure.Betweenness,
    CentralityMeasure.Closeness,
    CentralityMeasure.Harmonic,
    CentralityMeasure.Eigenvector,
    CentralityMeasure.PageRank
        //Note: CentralityMeasure.Coreness cannot be calculated
        //with directed relationships, so it is not included here.
        //Specfying Coreness (with directed or reveresed relationships) will
        //throw an exception
        //compute centrality
        var kg_centrality_results = kg.ComputeCentrality(
                                          kg_config, kg_subgraph, measures);
        //TODO process results
    Requirements
    ArcGIS Pro version: 3.6 or higher.
