ArcGIS.Desktop.Core Namespace / ICatalogWindow Interface / GetCurrentSecondaryPortalContentType Method
Example
    Gets the current catalog secondary portal content type being shown in the catalog dock pane
    Syntax
    Function GetCurrentSecondaryPortalContentType() As CatalogSecondaryPortalContentType
    CatalogSecondaryPortalContentType GetCurrentSecondaryPortalContentType()
    Return Value
    Remarks
    If the catalog dockpane is not the current active window and/or the GetCurrentContentType is not CatalogContentType.Portal, CatalogSecondaryPortalContentType.Unknown is returned.
    Example
    Get the secondary portal catalog content
      //Gets the Catalog pane
      var catalogWindow = Project.GetCatalogPane() as ICatalogWindow;
      var catContentType = catalogWindow.GetCurrentContentType();
      //Is Portal the content type?
      if (catContentType == CatalogContentType.Portal)
        //check what is the portal content type being shown...
        var secondaryContentType =
          catalogWindow.GetCurrentSecondaryPortalContentType();
        //TODO use secondary portal content type...
    Set the secondary portal catalog content
      if (!catalogWindow.IsActiveWindow)
        //catalog dockpane must be the active window
      //Is portal content being shown?
        var portalContentType = (int)catalogWindow.GetCurrentSecondaryPortalContentType();
        //advance to the next tab
        portalContentType++;
        if (portalContentType > (int)CatalogSecondaryPortalContentType.LivingAtlas)
          portalContentType = (int)CatalogSecondaryPortalContentType.UserContent;
        //set the secondary portal content type
        //Must be on the UI - no QueuedTask!
        catalogWindow.SetSecondaryPortalContentTypeAsync(
          (CatalogSecondaryPortalContentType)portalContentType);
    Requirements
    ArcGIS Pro version: 3.6 or higher.
