ArcGIS.Desktop.Mapping Namespace / ParcelFabricExtensions Class / GetSequencedParcelEdgeInfoAsync Method / GetSequencedParcelEdgeInfoAsync(ParcelLayer,Layer,Int64,MapPoint,SequencedEdgeParcelParams) Method
The parcel layer.
The layer of the parcel type.
The object Id of the parcel polygon feature that is used to get parcel edge lines of the same type.
The map point coordinate location to the nearest edge’s end to start a clockwise search trace.
Parameters that define tolerances and output filtering.
    Gets a clockwise ordered sequence of parcel edges, and their lines, in the same parcel type as the input parcel, and filtering the result by specifying the desired line-to-edge relationships.
    Syntax
    Parameters
    parcelLayer
    The parcel layer.
    parcelTypePolygonLayer
    oid
    startPointHint
    sequenceParams
    Return Value
    Exceptions
    ExceptionDescription
    Insufficient license. This method requires a standard license.
    parcelLayer cannot be null.
    parcelTypePolygonLayer cannot be null.
    sequenceParams cannot be null.
    oid cannot be negative.
    Requirements
    ArcGIS Pro version: 3.6 or higher.
