ArcGIS.Core.CIM Namespace / CIMKnowledgeGraphMultipleTypeLookup Class
Properties Methods Events
    CIMKnowledgeGraphMultipleTypeLookup Class Members
    The following tables list the members exposed by CIMKnowledgeGraphMultipleTypeLookup.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the default type name for the multiple type lookup. If the lookup fails, this type will be used to create a new entity. When empty or blank, if the lookup fails, nothing will be created.
    Public Property Gets or sets the information required to look up an entity by matching specific property values within specific types.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMKnowledgeGraphMultipleTypeLookup.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMKnowledgeGraphMultipleTypeLookup with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMKnowledgeGraphMultipleTypeLookup and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
