ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraph Class / TransformToObjectIDs Method / TransformToObjectIDs(String,IEnumerable<Object>) Method
Name of the Knowledge Graph type the ids are associated with.
The set of ids to translate.
Example
    Translates a set of ids for a Knowledge Graph type into objectIDs. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function TransformToObjectIDs( _
       ByVal typeName As String, _
       ByVal ids As IEnumerable(Of Object) _
    ) As IReadOnlyList(Of Long)
    public IReadOnlyList<long> TransformToObjectIDs(
       string typeName,
       IEnumerable<object> ids
    Parameters
    typeName
    ids
    Return Value
    The set of object IDs
    Exceptions
    ExceptionDescription
    typeName cannot be empty or null.
    Example
    Transform a set of IDs to objectIDs for an entity
      await QueuedTask.Run(() =>
        var idList = new List<object>() { "{CA2EF786-A10E-4B40-9737-9BDDDEA127B0}",
                                     "{14B5AD65-890D-4062-90A7-C42C23B0066E}",
                                     "{A428D1F6-CB00-4559-AAFD-40885A4F2340}"};
        var kg_props =
                new KnowledgeGraphConnectionProperties(new Uri(url));
        //Connect to the KnowledgeGraph datastore
        //KnowledgeGraph datastores contain tables and feature classes
        using (var kg = new KnowledgeGraph(kg_props))
          string entityName = "Name-of-the-entity";
          var oidList = kg.TransformToObjectIDs(entityName, idList);
    Requirements
    ArcGIS Pro version: 3.6 or higher.
