ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphIDSet Class / FromKnowledgeGraph Method / FromKnowledgeGraph(KnowledgeGraph,KnowledgeGraphFilterMethod) Method
A knowledge graph datastore.
The set of named type objects to include in the filter.
    Creates a KnowledgeGraphIDSet with a particular filter. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Shared Function FromKnowledgeGraph( _
       ByVal knowledgeGraph As KnowledgeGraph, _
       ByVal filterMethod As KnowledgeGraphFilterMethod _
    ) As KnowledgeGraphIDSet
    Parameters
    knowledgeGraph
    filterMethod
    Return Value
    Exceptions
    ExceptionDescription
    The knowledgeGraph is null.
    Requirements
    ArcGIS Pro version: 3.6 or higher.
