ArcGIS.Desktop.Mapping Namespace / FeatureSceneLayer Class / SearchEx Method
A query filter or spatial filter
If set to true, all the entries in RowCursor will reference the most current row returned by Current. To ensure all the entries in RowCursor remain unique, set useRecyclingCursor to false. The default is true.
    SearchEx Method (FeatureSceneLayer)
    Search for features based upon the specified attribute and/or spatial criteria. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function SearchEx( _
       Optional ByVal queryFilter As QueryFilter, _
       Optional ByVal useRecyclingCursor As Boolean _
    ) As RowCursor
    Parameters
    queryFilter
    useRecyclingCursor
    Return Value
    Exceptions
    ExceptionDescription
    No associated feature service
    A geodatabase-related exception has occurred.
    Remarks
    SearchEx can only be used on feature scene layers that have an associated feature service. Check HasAssociatedFeatureService property to determine if the FeatureSceneLayer has an associated feature service. Calling SearchEx() on a FeatureSceneLayer with no associated feature service will throw a System.InvalidOperationException
    Requirements
    ArcGIS Pro version: 3.6 or higher.
