ArcGIS.Core.CIM Namespace / CIMMarkerPlacementAlongLine Class / CustomEndingOffset Property
    CustomEndingOffset Property (CIMMarkerPlacementAlongLine)
    Gets or sets where the pattern should end relative to the ending point of the geometry. The entire pattern is shifted along the line for the specified distance. Negative numbers shift to the left and positive numbers shift to the right. This is only applied if the Endings property is set to Custom.
    Syntax
    public double CustomEndingOffset {get; set;}
    Public Property CustomEndingOffset As Double
    Requirements
