ArcGIS.Core.CIM Namespace / CIMMarkerPlacementAlongLine Class
Properties Methods Events
    CIMMarkerPlacementAlongLine Class Members
    The following tables list the members exposed by CIMMarkerPlacementAlongLine.
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether to angle the marker to the line. (Inherited from ArcGIS.Core.CIM.CIMMarkerStrokePlacement)
    Public Property Gets or sets where the pattern should end relative to the ending point of the geometry. The entire pattern is shifted along the line for the specified distance. Negative numbers shift to the left and positive numbers shift to the right. This is only applied if the Endings property is set to Custom.
    Public Property Gets or sets how markers are placed at the end points of a line.
    Public Property Gets or sets a value indicating whether to keep the marker upright. This is only considered if AngleToLine is true. (Inherited from ArcGIS.Core.CIM.CIMMarkerStrokePlacement)
    Public Property Gets or sets the offset. (Inherited from ArcGIS.Core.CIM.CIMMarkerStrokePlacement)
    Public Property Gets or sets where the pattern should begin relative to the starting point of the geometry. The entire pattern is shifted along the line for the specified distance. Negative numbers shift to the left and positive numbers shift to the right. This is only applied if the Endings property is set to No Constraint or Custom.
    Public Property Gets or sets the numeric pattern that defines the sequence of placed markers and the length of space between them.
    Public Property Gets or sets a value indicating whether to consider individual geometry parts or the whole geometry. (Inherited from ArcGIS.Core.CIM.CIMMarkerPlacement)
    Public Property Gets or sets the primitive name. (Inherited from ArcGIS.Core.CIM.CIMMarkerPlacement)
    Top
    Public Methods
     NameDescription
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Creates a JSON encoding of the CIMObject and its current state. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
