ArcGIS.Core.CIM Namespace / CIMFloorAwareMapProperties Class
Properties Methods Events
    CIMFloorAwareMapProperties Class Members
    The following tables list the members exposed by CIMFloorAwareMapProperties.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the default properties for the map's floor filter control. Used as default when creating new map views.
    Public Property Gets or sets the properties for the Indoors Facilities layer in the map.
    Public Property Gets or sets the properties for the Indoors Levels layer in the map.
    Public Property Gets or sets the properties for the Indoors Sites layer in the map.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMFloorAwareMapProperties.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMFloorAwareMapProperties with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMFloorAwareMapProperties and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
