ArcGIS.Desktop.Mapping Namespace / LasPointPipelineSelectionFilter Class / MinimumLength Property
Example
    Gets and sets the minimum length value in meters. This is the minimum length that the modeling will correct for wind with power lines longer than this distance. The default value is 20 meters.
    Syntax
    Public Property MinimumLength As Double
    public double MinimumLength {get; set;}
    Remarks
    This value is only applied if ApplyWindCorrection is true.
    Example
    Select using LasPointPipelineSelectionFilter
      // must be on MCT
      var pipelineFilter = new LasPointPipelineSelectionFilter();
      pipelineFilter.VisiblePoints = true;
      pipelineFilter.ClassCodes = new List<int>();  // empty list means all classification codes
      pipelineFilter.FilterGeometry = polygon;
      // configure a few of the properties and accept defaults for others
      pipelineFilter.ApplyWindCorrection = true;
      pipelineFilter.MinimumLength = 25;  // meters
      var pipelineSelCount = await lasDatasetLayer.SelectAsync(pipelineFilter, SelectionCombinationMethod.New);
    Requirements
    ArcGIS Pro version: 3.6 or higher.
