ArcGIS.Desktop.Mapping Namespace / LasPointPlaneSelectionFilter Class
Properties
    LasPointPlaneSelectionFilter Class Members
    The following tables list the members exposed by LasPointPlaneSelectionFilter.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the list of classification codes to be used in the selection filter. (Inherited from ArcGIS.Desktop.Mapping.LasPointSelectionFilter)
    Public Property Gets and sets the cluster distance in meters. The default value is 0.2 meters.
    Public Property Gets and sets the geometry to use for the selection filter. This must be a non-empty geometry and should be defined in screen coordinates or in coordinates of the map's spatial reference. (Inherited from ArcGIS.Desktop.Mapping.LasPointSelectionFilter)
    Public Property Gets and sets the maximum distance in meters. The default value is 6.09 meters.
    Public Property Gets and sets the plane tolerance value in meters. The default value is 0.152 meters.
    Public Property Gets and sets whether only visible points are to be used in the selection filter. Default value is null indicating don't change the existing visible points setting. (Inherited from ArcGIS.Desktop.Mapping.LasPointSelectionFilter)
    Top
