ArcGIS.Core.CIM Namespace / CIMMarkerPlacementInsidePolygon Class
Properties Methods Events
    CIMMarkerPlacementInsidePolygon Class Members
    The following tables list the members exposed by CIMMarkerPlacementInsidePolygon.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the clipping option which specifies how markers should be clipped at the polygon boundary.
    Public Property Gets or sets the orientation angle that the markers are placed on within the polygon.
    Public Property Gets or sets the grid type which defines how markers are placed.
    Public Property Gets or sets the marker row offset horizontally.
    Public Property Gets or sets the marker row offset vertically.
    Public Property Gets or sets a value indicating whether to consider individual geometry parts or the whole geometry. (Inherited from ArcGIS.Core.CIM.CIMMarkerPlacement)
    Public Property Gets or sets the primitive name. (Inherited from ArcGIS.Core.CIM.CIMMarkerPlacement)
    Public Property Gets or sets the randomness of the pattern when markers are placed randomly in a polygon.
    Public Property Gets or sets the starting value for generating a random pattern.
    Public Property Gets or sets a value indicating whether every other row of markers should be shifted to create an offset grid.
    Public Property Gets or sets the distance between each marker on the X-axis of the grid.
    Public Property Gets or sets the distance between each marker on the Y-axis of the grid.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMMarkerPlacementInsidePolygon.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMMarkerPlacementInsidePolygon with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMMarkerPlacementInsidePolygon and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
